The V-Ray installation location could can be obtained by 3rd parties through the 3ds Max’s PluginPackageManager. The upgradeCode is "{00B38902-1C59-405A-875E-A9E3461F1FE7}"
For the sake of portability V-Ray for 3ds Max is installed in a single directory under the application plug-ins location, known further as PKGROOT. The accompanying V-Ray Standalone files are there too. The package is in a directory named “VRay3dsMax<3ds VRay3dsMax<3ds Max version>”version>. This should allow for distribution by just copying the whole package and setting the environment variables.
width20%
width60%
Image Modified
width20%
The V-Ray SDK, example projects documentation installer and its logs as files not essential to rendering are still in their former place (defaulting to “Cby default at C:\Program Files\ChaosGroup\V-Ray\3ds Max <3ds Max version>”version>) further known as INSTALLROOT.
Package element
Description
Former location
[PKGROOT]/amg
viewport shaders
<Program Files>\Autodesk\3ds Max*\AMG
[PKGROOT]/assets
files needed for V-Ray for 3ds Max e.g. material_preview.vrscene
<Program Files>\Chaos Group\V-Ray\3ds Max*\assets
[PKGROOT]/bin
V-Ray GPU binaries and plugins
<Program Files>\Chaos Group\V-Ray\3ds Max*\bin
[PKGROOT]/defaults
3ds Max defaults settings
<Program Files>\Autodesk\3ds Max*\en-US\defaults
[PKGROOT]/docs
V-Ray EULA
<Program Files>\Chaos Group\V-Ray\3ds Max*\docs
[PKGROOT]/openslVRayOSL headers<Program Files>\Chaos Group\V-Ray\3ds Max*\opensl
[PKGROOT]/pluginsV-Ray for 3ds Max plugins<Program Files>\Autodesk\3ds Max*\Plugins
[PKGROOT]/resourcesV-Ray Toolbar icons<Program Files>\Autodesk\3ds Max*\UI_ln
[PKGROOT]/sceneconverter3ds Max scene converter scripts (and presets)<Program Files>\Autodesk\3ds Max*\SceneConverter
[PKGROOT]/scripts3ds Max startup scripts<Program Files>\Autodesk\3ds Max*\scripts
[PKGROOT]/PackageContents.xmlThe Autodesk application package descriptor
[INSTALLROOT]/docs
V-Ray SDK documentation shipped
[INSTALLROOT]/include
V-Ray SDK headers
<Program Files>\Chaos Group\V-Ray\3ds Max*\include
[INSTALLROOT]/lib
V-Ray SDK export libraries
<Program Files>\Chaos Group\V-Ray\3ds Max*\lib
[INSTALLROOT]/mdl
VRayMDL sample shaders
<Program Files>\Chaos Group\V-Ray\3ds Max*\mdl
[INSTALLROOT]/samples
V-Ray SDK sample projects
<Program Files>\Chaos Group\V-Ray\3ds Max*\samples
[INSTALLROOT]/uninstall
V-Ray installer's binary, config and log
<Program Files>\Chaos Group\V-Ray\3ds Max*\uninstall
[INSTALLROOT]/utils
Other products installations that are bundled with V-Ray
<Program Files>\Chaos Group\V-Ray\3ds Max*\utils
