V-Ray GPU is a separate render engine, introduced by Chaos, that utilizes GPU hardware acceleration. You can additionally use it with your CPU or combine CPU and GPU devices for hybrid rendering. Choosing the V-Ray GPU engine changes the available settings.
UI Text Box
type
tip
Refer to the V-Ray and MAXScript page for information on how to access the parameters through MAXScript.
UI Text Box
type
info
The Common tab contains no custom or unique V-Ray settings. For more details on the parameters found under this tab, please refer to the 3ds Max help documentation.
