Through the V-Ray tab in the Render Setup window you can access the settings of the Renderer, Global Illumination, V-Ray Frame buffer, and Environment. Depending on the chosen GI engine, a Brute Force or Light Cache rollout is also available under this tab.
UI Expand
title
UI Path:||Render Setup window|| >V-Raytab (Rendererset to V-Ray GPU)
Image Removed
width
5%
width
35%
Image Modified
Rollouts
The GPU V-Ray tab consists of four or five (when GI is set to Light Cache) rollouts:
