In 3ds Max 2021 and above, the newer Bake to Texture feature is also available and works with the V-Ray bake elements.
UI Expand | ||||||||||||||||||||||||||||||||||
||Renderingmenu|| > Bake to Texture > Select bake elements > Add Maps to Selected Objects button (for 3ds Max 2021 and newer)
Rendering menu ||Rendering menu|| > Render To Texture > Output rollout > Add button > Select bake element > Add Elements button (for older versions of 3ds Max)
