UI Expand
expandedtrue
titleUI Path: Rendering menu >...
||Renderingmenu|| > Bake to Texture > Select bake elements > Add Maps to Selected Objects button (for 3ds Max 2021 and newer)
width20%
width60%
Image Modified
width20%40%
||Rendering menu|| > Render To Texture > Output rollout > Add button > Select bake element > Add Elements button (for older versions of 3ds Max)
width50%35%
width1%10%
width30%
Image Added
width49%25%
 Image Removed
Bake Elements
