VRayColor2Bump is a V-Ray utility node that converts any RGB texture into a bump map. VRayColor2Bump is best used within a texture network that does not support bump mapping (e.g. a bump map going through color correction). VRayColor2Bump is slower to calculate because it needs to evaluate the texture at multiple points, but it can be used within any texture shading network. Directly plugging a bump map into the network is faster and should be used whenever possible, leaving the use of VRayColor2Bump for times when other options are not possible.
