UI Text Box | ||
When a modifier is added, the proxy loses its memory-saving properties and is regarded as just a regular mesh in the scene. Therefore, it is recommended to perform modifications on the original mesh prior to exporting it to vrmesh or alembic and not the VRayProxy object. The Show whole mesh display type should be used for the VRayProxy if modifiers are applied. |
UI Expand | |||||||||||||||||||||||||||||||||||||||||
