UI Expand
titleUI Path: ||Render Setup window|| > Render Elements tab > Add button > VRayCoatReflection
Image Removed
Image Added
width60%
VRayVFB – When enabled, the render element appears in the V-Ray Frame Buffer.
Color mapping – Applies the color mapping options specified in the Color mapping rollout (Render Setup window > V-Ray tab) to this render element. This option is enabled by default.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
width5%
width35%
Image RemovedImage Added
