width60%
The Raw Total Lighting Render Element is the sum of all raw lighting (both direct and indirect) in the scene, without any diffuse details. This render element is useful for changing the appearance of the scene's lighting in a compositing or image editing application.
UI Expand
titleUI Path: ||Render Setup window|| > Render Elements tab > Add button > VRayRawTotalLighting
Image RemovedImage Added
width5%
width35%
