Div
stylemargin-top: 10px
idFireSource_Overview
width50%
You can use the Fire Source to emit fire and smoke into Fire/Smoke Simulators. It's not a problem to use it for emitting liquid as well, but you have to understand Grid Channel ranges well.
You can emit fluid from geometry or from particles. The fluid can be emitted from the surface, or from the entire volume of emitting geometry. Particles can emit from a spherical shape, or from instanced geometry shapes. Note that the viewport gizmo of the Source does not emit fluid itself - you have to first pick the geometry or particles you would use as emitters in the Source's list.
The position of the Source icon in the scene does not matter. If you have many Simulators in the scene, by default each Simulator will interact with a Source'
s Emitter
Nodes
Nodes as long as they are inside this Simulator. You can exclude Sources or Emitters from a Simulator's Scene Interaction rollout. If you use Include mode, you have to pick both the Source and its Emitter Nodes in
the Interaction
the Interaction List.
The Source can emit in 3 different Emit Modes - Surface Force mode creates fluid only at the surface of emitters, Volume Brush fills the entire volume of the emitters, and Volume Inject also fills the emitter's volume and adds pressure for an explosive effect.
You can emit any fluid grid channel and you can emit many channels at once. Additionally, you can emit particles from the Source. If you want to emit unevenly only from some areas or volumes of the emitters, you can use a Mask for each of the emission channels. Also, note that
if Emit
if Emit Mode is set to Volume Brush or Volume
Inject and the Mask uses
Inject and the Mask uses Explicit Map Channel or Vertex Color Channel mapping, then the
Mask will
Mask will be applied on the whole volume, based on the closest geometry surface.
Additionally, each channel can have one or many Discharge Modifiers. They allow you to gain more precise procedural control over how the fluid gets emitted. Discharge modifiers vary the emission over different parts of the emitter depending on properties of the emitter - e.g. the direction of its normals, the speed of movement at each point of an animated emitter, etc.
width50%
Image Added
UI Expand
titleUI Path: ||Create panel|| > Helpers > Phoenix FD category > PHXSource button
Emitter Nodes
width60%
Div
idFireSource_EmitterNodes
Emitter Nodes | sources – Specifies a list of objects that will emit fluid. Both geometry and particle systems can be selected here. Press the Add button and pick an object from the Viewport, or a list of objects using the Scene Explorer.
width5%
width35%
