Release notes: V-Ray 6, Beta
V-Ray 6 for Maya, beta is here.
This new version brings in powerful tools that will enable you to create faster and render better than ever before. Explore all that’s new, and help us make V-Ray 6 our best version yet.
UI Button
colorblue
icondownload
titleTry V-Ray 6 for Maya, Sign up for the beta
urlhttps://try.chaos.com/beta-vray-maya
width45%
V-Ray Sun
Procedural Clouds
Craft just the right cloudy sky for your environment in just a few clicks with V-Ray’s new procedural clouds system.
For more information, see the VRaySun page.Learn more
width5%
width50%
width45%
V-Ray Enmesh
Apply intricate geometric patterns across surfaces as many times you like, at no extra memory cost. Create beautiful chain mails, fences, knitted fabrics, fences, and much more in just a few clicks.
For more information, see the Enmesh page.Learn more
width5%
width50%
width45%
Thin Film Layer
Create realistic soap bubbles, oil spills, and more with the new Thin Film option in the V-Ray Material.
See the VRayMtl 's page.
width5%
width50%
width45%
New ground projection
Finite Dome light mode
Elevate your HDRI environment renders with the new, more flexible ground projection capabilities of the V-Ray Dome Light. Set the scale of a dome light, and have full control over blend settings with the new finite mode.
width5%
width50%
Before after
afterLabelFinite
beforeLabelInfinite
Panel
borderStylenone
Panel
borderStylenone
width45%
Enhanced V-Ray Material energy preservation
Render even more physically accurate rough metals and other reflective surfaces with enhanced V-Ray Material energy preservation.
See the VRayMtl's page.
width5%
width50%
width30%
Streamlined USD Support
VRayMtl can be exported as a USDPreviewSurface, so that Experience a USD workflow that’s smoother than ever. Export V-Ray Materials as USD Preview Surfaces and have V-Ray assets can be displayed in various non-V-Ray viewports. Find out Plus more at USD.
width5%
width30%
V-Ray Material Faster Translucency
Render translucent materials even faster with a brand-new V-Ray Material SSS mode.
width5%
width30%
Light Cache in IPR
IPR can now use the Light Cache GI, making IPR and production renders identical.
width30%
VFB Panorama Viewer
Now you You can now preview your spherical panorama renders while rendering, right from your V-Ray Frame Buffer.
width5%
width30%
Composition Guides Layer in VFB
Fine-tune your scenes’ compositions without going to a separate application. With customizable overlays, the new composition guides layer in the VFB allows you to easily experiment and enhance your image compositionsSubmit your work to Chaos Cloud without any interruptions. You can continue working on your projects, while V-Ray exports your scene for cloud rendering. Find out more at V-Ray Frame Buffer Layers.
width5%
width30%
Non-blocking Submit to
Enhanced Chaos Cloud Experience
Submitting to the Chaos Cloud now happens in a separate process, which leaves the Maya interface free so that users can continue working. See the Chaos Cloud page.
width30%
width5%
width30%
V-Ray Profiler
V-Ray now reports how much time was spent in calculating each material in the sceneGet reports on the time spent calculating materials in your scenes. Paired with the memory tracker this rounds up , you now have a complete set of tools toolset for monitoring and managing the rendering performance. See the V-Ray Profiler page.
Learn more
width5%
width30%
And more. See the complete feature list>
