Opens the Convert Scene for V-Ray window where you can convert a material to a VRayMtl. Note that for now it works only for standardSurface material and aiStandardSurface material, and that it doesn't convert dispersion, sheen, coat, sss.
UI Path: ||V-Ray Menu|| > Tools > Convert Scene for V-Ray
width
5%
width
33%
Image Removed
Image Added
width
62%
Connect Materials – When enabled, assigns the converted material back to the geometry. When disabled, the converted materials have to be manually assigned.
Create Adapter Notes – When enabled, creates intermediary nodes to better match the original material. When disabled, produces simpler shading networks, but at the expense of visual parity.
Convert All – Converts all materials to V-Ray materials.
Convert Selected – Converts only the selected materials to V-Ray materials.
Cancel – Closes the window and cancels the conversion of the materials.
