This page covers the basics of using XGen with V-Ray for Maya, including a step-by-step guide to controlling XGen Attributes through texture maps.
Prerequisites
Section | |||||
Section | |||||
Basics
Section | |||||||||||||||
The following images below show how instanced primitives look when the base mesh has a low versus a high subdivision; note . Note how XGen clumps primitives more to the center of each face. This is the same behavior for all kinds of primitives.
Part I: Through Expressions
Section | |||||
Section | |||||
Part II: Through Texture Maps
- Create a plane and create an XGen description on it, with splines randomly across the surface.
- Increase the Density from the Primitives tab of the XGen window to 50.
Set Up the Map
Section | |||||
Section | ||||
Section | |||||
Section | |||||
Section | |||||
