width45%
Thin Film Layer
Create realistic soap bubbles, oil spills, and more with the new Thin Film option in the V-Ray Material.
width5%
width50%
width45%
Enhanced V-Ray Material energy preservation
Render even more physically accurate rough metals and other reflective surfaces with enhanced V-Ray Material energy preservation.
width5%
width50%
width30%
VFB Panorama Viewer
You can now preview your spherical panorama renders while rendering, right from your V-Ray Frame Buffer.
width5%
width30%
Composition Guides Layer in VFB
Submit your work to Chaos Cloud without any interruptions. You can continue working on your projects, while V-Ray exports your scene for cloud rendering. Find out more at V-Ray Frame Buffer Layers.
width5%
width30%
Enhanced Chaos Cloud Experience
Submitting to the Chaos Cloud now happens in a separate process, which leaves the Maya interface free so that users can continue working. See the Chaos Cloud page.
width30%
Portable Installation
The V-Ray installation file can be unpacked and used as a portable version, instead of the old archive versions.
Learn more
width5%
width30%
V-Ray Profiler
Get reports on the time spent calculating materials in your scenes. Paired with the memory tracker, you now have a complete toolset for monitoring and managing rendering performance.
Learn more
width5%
width30%
