UI Text Box | ||
UI Path: ||Select PhoenixFDSim|| > Attribute Editor > Rendering rollout > Smoke Color rollout |
Based on | difSource – Specifies the source channel that will be used to determine the smoke color. By default, a uniform simple color set by the Constant Color option is used. This could also be a texture map, or read from the cache files - in that case the corresponding grid channel must be enabled from the Output rollout before the simulation is run.
