Map – A slot to load the map that you want to convert to a bump map.
Height – A multiplier for the height of the bump effect. This basically makes the map brighter or darker.
Bump delta scale– Controls the softness/sharpness of the bump effect. Lower values generate sharper transitions in the bump effect while higher values generate a softer looking bumpeffect.
