The Input rollout The Input rollout determines the path of the input cache files for rendering and previewpreviewing, as well as the provides controls for playback effects. Note that some playback settings require a fractional input frame, in which case the frame is blended between the previous and the next one.
UI Text Box
typeinfo
To set up rendering and simulation cache paths manually, see Chaning Changing the Default Phoenix Paths in the Tips and Tricks page.
UI Text Box
typenote
Note that some playback settings require a fractional input frame, in which case, the frame is blended between the previous and the next one.
UI Text Box
typetip
UI Path: ||Select Liquid Simulator | LiquidSim object|| > Modify panel > Input rollout
