The Input rollout The Input rollout determines the path of the input cache files for rendering and preview previewing, as well as the provides controls for playback effects.
Note that some playback settings require a fractional input frame, in which case, the frame is blended between the previous and the next one.
UI Text Box | ||
To set up rendering and simulation cache paths manually, see Chaning see Changing the Default Phoenix Paths in in the Tips and Tricks page. |
UI Text Box | ||
UI Path: ||Select PhoenixFDSim|| > Attribute Editor > Input rollout |
Cached Frames – Shows information about the cached frame range.
