width25%
width50%
Image slider
startIndex1
Panel
borderStylenone
Phase Function = -0.5
Panel
borderStylenone
Phase Function = 0
Panel
borderStylenone
Phase Function = 0.5
width25%
width5%
width30%
Image Added Phase Function = -0.5 (Backward Scattering)
width30%
Image Added Phase Function = 0 (Isotropic Scattering)
width30%
Image Added
Phase Function = 0.5 (Forward Scattering)
The red arrow represents a ray of light going through the volume; the black arrows represent possible scattering directions for the ray.
Anchor
smokeColorBySpeed
smokeColorBySpeed
Example: Smoke Color Based on Speed
UI Text Box
typetip
The Smoke Color can be based on any channel present in the cache files. The Speed channel can be used to drive the color of the smoke. It is automatically generated by Phoenix based on the Velocity Grid Channel. In this example, the slowly moving smoke is blue while the fast moving smoke is red to yellow.
Videoautoplayloop
0SmokeColorBasedOnSpeed720p.mp4
1720
2100%
3true
4false
5true
