width57%55%
OptionDescription
Start Production RenderStarts Production render in the VFB.
Start Interactive RenderStarts Interactive render in the VFB.
Submit to Chaos CloudSubmits your current scene for render to Chaos Cloud.
V-Ray VFBOpens the New V-Ray Frame Buffer window.
Render ElementsOpens the Render Elements window.
Cosmos BrowserOpens the Chaos Cosmos browser.
Vantage Live LinkStarts a Vantage Live Link.
LightsOpens the Lights submenu.
CamerasOpens the Cameras submenu.
GeometryOpens the Geometry submenu.
Volumetrics Opens the Volumetrics submenu.
ToolsOpens the Tools submenu.
HelpOpens the Help submenu.
width5%
width38%40%
Image Modified
width57%
Rectangle LightCreates a Rectangle Light.
Sphere LightCreates a Sphere light.
Dome LightCreates a Dome light.
Mesh LightCreates a Mesh Light.
IES LightCreates an IES light.
V-Ray SunCreates a V-Ray Sun.
V-Ray Sun with SkyCreates a V-Ray Sun and Sky system.
width5%
width38%
Image Modified
width57%
Physical CameraCreates a Physical camera.
width5%
width38%
Image RemovedImage Added
width57%
V-Ray ParticlesCreates a V-Ray Particles object in the scene.
V-Ray Proxy
Creates a V-Ray Proxy object.
V-Ray SceneCreates a V-Ray Scene object.
V-Ray FurApplies fur properties to the selected object.
V-Ray ClipperMakes the selected object a clipper.
V-Ray DecalCreates a V-Ray Decal object.
V-Ray EnmeshCreates a V-Ray Enmesh geometry.
width5%
width38%
width57%
V-Ray VolumeGridCreates a V-Ray VolumeGrid.
Environment FogCreates an Environment fog.
width5%
width38%
width57%
Light ListerOpens the Light Lister window.
Make Shadow CatcherConverts the selected object into a Shadow Catcher Matte object.
Convert MaterialsConverts materials from one type to another.
Convert V-Ray 3 sceneOpens the Convert V-Ray 3 scene tool.
width5%
width38%
Image Modified
width57%
AboutOpens an About window.
Online DocumentationOpens the V-Ray for Cinema 4D documentation in a browser.
Online Help CenterOpens the Chaos Group Help center in a browser.
Check for UpdateChecks if a newer V-Ray version is available for download.
width5%
width38%
width57%
The About window contains information about the current V-Ray version installed, copyright notice and information if this is the latest released version or there is a newer update available for download.
width5%
width38%
width45%
Edit > Preferences > Renderer > V-Ray
See more information at the Preferences V-Ray Menu page.
width10%
width45%
width45%
 Create toolbar > ||V-Ray|| > V-Ray
Image Modified
width10%
width45%
Create > ||Create|| > V-Ray (disabled Separate menu for V-Ray materials)
Image Modified
width45%
You can access V-Ray log from from Extensions > Console > V-Ray
width10%
width45%
