changes.mady.by.user Lyubomira Toshkova
Saved on Dec 29, 2021
Saved on Aug 23, 2022
||V-Ray Asset Editor|| > Geometry (right-click) > Displacement
||V-Ray Asset Editor|| > Create Asset (left-click) > Geometries > Displacement
Image RemovedImage Added
||V-Ray Objects Toolbar|| > Displacement (left-click) > Add Displacement properties to the selection
||V-Ray Objects Toolbar|| > Displacement (right-click) > Remove the Displacement properties from the selection
Image AddedImage Removed
||V-Ray|| > V-Ray Objects > Add Displacement to Selection
Create and apply Displacement to the selection . You can use any of the ways shown in the UI path section.
Here Displacement is created from the Asset Editor and applied to the selection.
Then, select the Bitmap as a Map and load a proper file (e.g., .exr). Make sure to select the proper Mode for the loaded map.
The result is seen upon rendering.
<iframe width="560" height="315" src="https://www.youtube.com/embed/-DBjjv6wlfo" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
