width60%
When rendering with V-Ray Standalone, an OCIO configuration can be set with the following VFB OCIO environment variables:
VRAY_VFB_OCIO_INPUT_COLORSPACE – Specifies default OCIO input color space.
VRAY_VFB_OCIO_DISPLAY_DEVICE – Specifies default OCIO display device.
VRAY_VFB_OCIO_VIEW_TRANSFORM – Specifies default OCIO view transform.
VRAY_VFB_OCIO – Automatically switches the OCIO button of the V-Ray VFB on.
For example, set a default OCIO input color space, display device, and view transform:
Code Block
set VRAY_VFB_OCIO = 1
set VRAY_VFB_OCIO_INPUT_COLORSPACE = ACES - ACEScg
set VRAY_VFB_OCIO_DISPLAY_DEVICE = ACES
set VRAY_VFB_OCIO_VIEW_TRANSFORM = sRGB
Note that without setting these variables, it is not possible to render in ACES color space with V-Ray Standalone
UI Text Box
typetip
These environment variables also work for V-Ray VFB in 3ds Max.
See the Getting Started with Environment Variables page for more information.
width5%
width35%
