width62%
The Raw Sheen Reflection Filter Render Element is similar to the Sheer Filter Render Element, except it is not affected by Fresnel falloff. The result is a solid mask showing the areas of reflection calculated for the VRayMtl Sheen Layer.
UI Expand
titleUI Path: ||Display Render Settings button|| > Render Elements tab > Raw Sheen Filter
width25%
width50%
Multiexcerpt include
MultiExcerptNameRE
PageWithExcerptRender Elements
width25%
width5%
width33%
