This page provides information about the Texture nodes in V-Ray for Cinema 4D.
UI Children
columns23
width38%
V-Ray Node Space offers a number of nodes arranged in the following categories: Color, Context, Material Generator, Material, Math, Surface and Utility.
V-Ray offers two output (Colored Node) nodes - Material and Two Sided Material. Each Node system holds only one output (Colored) node.
Some of the nodes are texture nodes used as utility or surface maps.
UI Text Box
typenote
V-Ray Node space is available in Cinema 4D versions 21.1 and later!
UI Text Box
typeinfo
V-Ray Texture Nodes are not interchangeable or compatible with the V-Ray (Classic) Textures.
width5%
width57%
Node Editor with V-Ray nodes in Cinema 4D R25.
