Materials with Normal opacity mode are now calculated with the Stochastic opacity mode. Stochastic is now the default mode and replaces Normal in old scenes, as it gives the same results but is faster. The Clip mode calculates faster and gives better and more accurate results when there is only pure white and pure black in the opacity map.
With V-Ray6 Ray 6 the Fresnel formula is now calculated more precisely. As a result, some materials, mainly metallic ones, may render slightly differently (with more physically-accurate reflections).
With V-Ray 6 the V-Ray Preset Material Library is part of the Chaos Cosmos Browser. Materials that have already been downloaded with any earlier V-Ray version remain unchanged and can still be loaded as a custom folder.
