This page provides information about the Camera/Postprocessing tab in the Render settings window.
Floatingpagetoc
Maxlvl4
width50%
The Camera/Postprocessing tab includes the settings that affect the rendered image.
UI Path: ||Render settings window|| > Corona > Camera/Postprocessing tab
width5%
width45%
Tone mapping
width50%
Configure – Launches the tone mapping settings dialog. The available tone mapping controllers are:
Contrast
Green-Magenta Tint
Photographic Exposure
Saturation
Simple Exposure
Tint
Vignette
White balance
Advanced Filmic Mapping
Curves
Filmic Mapping
Tone Curve
Reinhard Highlight Compression
ACES Output Transform
LUT
width5%
width45%
Basic photographic settings
width50%
ISO – The ISO is the camera's sensor light sensitivity, and it stands for “International International Organization for Standardization”Standardization. Using higher ISO values will increase increases the sensor light sensitivity, resulting in brighter images, but at the same time, it will introduce introduces more visible noise (grain) to the image.
Shutter speed [1/s] – The shutter speed controls the time that the camera's shutter will be is open, allowing light to be captured by the camera's sensor. This time could be either a fraction of a second or more than one whole second. When using a long shutter speed (in other words, exposing the camera's sensor for a significant period of time) and objects are moving, this will result results in blurred objects along the direction of motion; this is also known as motion blur. This effect is commonly used to communicate the sense of speed or motion. On the other hand, when using a fast shutter speed value (a small fraction of time), you could almost eliminate the object's motion, even from fast-moving objects like cars driving past.
F-stop – The f-stop value, also known as the f-number, is the ratio between the lens focal length and the aperture's diameter. The “f” f stands for “focal length” focal length and it is written as a fraction; in other words, think of an aperture of f/16 as 1/16 (one-sixteenth), or an aperture of f/8 is 1/8 (one-eighth). Using this same logic, an aperture of f/8 is larger than an aperture of f/16.
For example, if you have a 50mm f/2.8 lens, and the f-stop value is set to f/4, then the diameter of the aperture blades (or diaphragm) in your lens will be 12.5 mm (50mm / 4), whereas setting the f-stop at f/16, the diameter will be only 3.5 mm (50mm / 16), and so on.
Sensor width [mm] – This value describes the physical width of the camera's sensor. The sensor size can be measured in mm or inches. A "full-frame" sensor measures 36 x 24mm (W x h), and a "four-thirds" sensor ("4/3") measures 17 x 13mm (W x h).
UI Text Box
typenote
The ISO, Shutter speed, and F-stop values will only work if the "Photographic exposure" control is loaded in the "Tone mapping" section.
width5%
width45%
Bloom and glare
width50%
Size – This is the size of bloom and glare effect in the percentage of render size.
Bloom intensity – Linear scaling of the bloom effect (large, soft glow around bright areas); values greater than 0.0 enable the effect.
Glare intensity – Linear scaling of the glare effect (more focused glow with streaks); values greater than 0.0 enable the effect.
Color intensity – Adds color variation to the glare effect for additional artistic control.
Color shift – Alternates the colors created by the Color intensity option.
Use legacy (v5) effect – This option reproduces the bloom and glare behavior from a previous version.
Threshold – Only pixels brighter than this threshold are affected by bloom and glare. Increase this value to make the effect more localized around the brightest light sources only.
Streak count – Sets the number of streaks in the glare effect.
Rotation [°] – Alters the rotation of the glare effect.
Streak blur – Controls blurring of all streaks in the glare effect. A value equal to 0.0 results in very sharp streaks, while a value equal to 1.0 leads to over-blurred streaks.
width5%
width45%
Sharpening
width50%
Sharpening amount – Applies sharpening to the image. Increasing this amount leads to a sharper image, while setting the amount to zero switches off this filter.
Blur radius – Sets the pixel radius used during blurring. Higher values lead to a greater blurring effect.
Sharpening radius – Sets the pixel radius used during sharpening. Higher values lead to more extensive sharpening.
UI Text Box
typetip
Tip: All sharpening/blurring controls can be interactively changed during/after rendering in the VFB window.
width5%
width45%
Depth of field
width50%
Perspective view focus distanceThis value determines Determines the focal point distance measured from the camera to the end of the camera's frustum (a.k.a. camera's cone).
Aperture shapeThis option sets Sets the aperture shape that influences the out-of-focus blur called "bokeh". The options are:
Circular
Uses a circular aperture.
Bladed
The result is a polygonal aperture with a given number of sides (blades).
Custom
: This option uses
Uses a custom aperture shape defined by a shader or a texture map.
Bokeh center biasThis value introduces Introduces an offset for the bokeh effect. Values between -5 and 5 can be used here.
Bokeh vignettingThis value introduces Introduces a vignette around the bokeh effect. Values between -3 and 3 can be used here.
Bokeh anisotropyThis value deforms Deforms the bokeh effect. Depending on the value used, it can be deformed on one axis or another. For this option, values between -0.999 and 0.999 can be used.
width5%
width45%
Motion blur
width50%
Enable camera – Enables motion blur due to camera movement. For a complete motion blur solution, you need to enable objects motion blur as well.
Enable objects – Enables motion blur due to the movement of scene geometry. For a complete motion blur solution, you need to enable camera motion blur as well.
Transformation segments – Quality of the non-linear rigid (transformation) motion blur. Increasing this value increases the quality at the expense of some rendering speed and memory usage. Setting this value too low can result in movement stutter and/or artifacts.
Frame Offset – Offsets the time interval from which the motion blur effect is generated. The value is defined in frames, with 0 meaning that the center of the interval is exactly in the current frame, -1 meaning that the entire interval happens just before the current frame, and 1 meaning the entire interval happens just after the current frame.
UI Text Box
typenote
When using object motion blur with dynamics, the simulation should be cached to prevent artifacts in the final render.
width5%
width45%
Other Render settings tabs
Div
stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
aligncenter
classcoronatabsc4d
Textboxcard
PageToIncludeSystem Requirements
CardPageLinkGeneral settings
General settings
Textboxcard
PageToIncludeInstallation
CardPageLinkScene Environment
Scene Environment
Textboxcard
CardPageLinkPerformance Settings
Performance settings
Textboxcard
CardPageLinkFrame buffer settings
Textboxcard
CardPageLinkSecondary GI - UHD Cache
Secondary GI: UHD Cache
Textboxcard
PageToIncludeGetting Started
CardPageLinkTeam Render
Team render
