This page provides information on the Corona Data map , its settings, and usagein 3ds Max.
width55%
This Corona Data map outputs various data channels and is intended mainly for debugging purposes.
UI Text Box
typetip
This map can also be used to create some interesting effects – for example, coloring objects based on their viewport wire color.
width5%
width40%
width50%
Mode – This parameter allows you to select between different modes for extracting the data.
uifancy-expandbullets
typecircletitleClick here to know the available data extraction modes
  • Primitive type
  • Mesh component
  • Material ID
  • Primitive ID
  • Instance ID (source mode)
  • DUVW
  • Abs (DUVW)
  • Pixel: World ratio
  • World position
  • Shading normal
  • Geometry normal
  • Dot product shading
  • Z-Depth
  • Backside hit
  • Tangent
  • Object Space Normal
  • Object Gradient
  • Wire color
  • UVW
width5%
width45%
 Image Added
