width50%
Randomize by – Using this option, the occlusion can be controlled by a texture map or shader.
Available randomization modes:
  • Primitives – When this mode is used, each of the items (color or textures) will be randomly distributed on each mesh primitive (triangle).
  • Sub-primitive – When this mode is used,
  • Material name – When this mode is used, the items (color or textures) will be randomly applied to the different materials the Multi shader is assigned to.
  • Objects – When this mode is used, each of the items (color or textures) will be randomly distributed on each of the instances (objects).
  • Material tag index – When this mode is used, each of the items (color or textures) will be randomly distributed based on the object’s material ID.
  • Material ID – When this mode is used, each of the items (color or textures) will be randomly distributed based on the material’s Buffer ID.
    UI Text Box
    typenote
    Material IDs can be set via the advanced tab in each material.
  • Object buffer ID – When this mode is used, each of the items (color or textures) will be distributed based on the object’s Buffer ID.
    UI Text Box
    typenote
    Object Buffer's IDs can be set using the Corona Compositing tag for each object.
  • Mesh Element – When this mode is used, items (color or textures) will be randomly distributed on all mesh elements (in case the mesh consists of multiple elements).
  • Polygon – When this mode is used, items (color or textures) will be randomly distributed on all mesh faces. (only available in Corona 8 and newer)
  • Decal – When this mode is used, items (color or textures) will be randomly distributed per decal object. (only available in Corona 8 and newer)
  • Multiple properties – This option allows you to randomize the result by combining different modes.
Batch load textures – This option allows you to load multiple texture maps at the same time.
Layer count – This value defines the number of elements (layers) that will be randomized.
Mix amount – This value controls the blending of all elements (layers). A value of 100% will completely blend all element's colors or textures.
Blur multiplier – This
Seed – This value creates different randomizations.
Hue random – This value randomizes the Hue for each element (layer).
Saturation random – This value randomizes the Saturation for each element (layer).
Gamma random – This value randomizes the Gamma for each element (layer).
width5%
width45%
Blur multiplier = 100
width1%
width32%48%
Image slider
Corona Multi Shader Randomize by
Panel
titleRandomized by = Objects
Panel
titleRandomized by = Mesh elements
Panel
titleRandomized by = Polygons
width1%2%
width32%48%
Image slider
Corona Multi Shader Mix amount
Panel
titleMix amount = 0%
Panel
titleMix amount = 50%
Panel
titleMix amount = 100%
Corona Multi Shader Blur multiplier
width1%
width32%
Image slider
Panel
titleBlur multiplier = 1
Panel
titleBlur multiplier = 50
Panel
title
width1%
width32%
Image slider
Corona Multi Shader Hue random
Panel
titleHue random = 0%
Panel
titleHue random = 50%
Panel
titleHue random = 100%
width1%
width32%
Image slider
Corona Multi Shader Saturation random
Panel
titleSaturation random = 0%
Panel
titleSaturation random = 50%
Panel
titleSaturation random = 100%
width1%
width32%
Image slider
Corona Multi Shader Gamma random
Panel
titleGamma random = 0%
Panel
titleGamma random = 15%
Panel
titleGamma random = 30%
