Using the Corona Light Material with Corona Decals
width20%
width60%
The Corona Light Material can be applied to Corona Decals. (Corona Physical Material with self-illumination can be used like this as well!)
In this example, Graffiti textures are being used as the emission texture of a Corona Light Material which is being projected by the Corona Decals.
Image AddedImage Removed
UI Expand
titleClick here to see the viewport preview:
Image RemovedImage Added
width20%
