Displacement – Blending modes
width1%
width32%
Displacement mode: Only from base material
In this mode, the displacement only from the base material is applied to the object.
UI Expand
titleClick here to see the Material setup.
width1%
width32%
Displacement mode: Blend all layers
This is the default mode for displacement. This is like stacking displacement maps from the base material and layered materials like layers on top of each other without any special blending mode; then they can be mixed by changing their opacity.
UI Expand
width1%
width32%
Displacement mode: Add all layers on top
This is like stacking displacement maps like layers on top of each other and using “Add” blending mode to mix them (then their strengths can be affected by the "Amount" value).
UI Expand
width1%
width48%
Corona Layered Material – Example A
UI Expand
width4%
width48%
Corona Layered Material – Example B
UI Expand
Image RemovedImage Added
