This page provides information on the V-Ray and Enscape compatibility in Rhino.
Section | ||||||||||||||||
Material Support
Material Support
If you wish to edit a Rhino or Enscape material with V-Ray to take advantage of advanced material options, use the Rhino Material panel to change the material type to V-Ray. Once a material is converted to V-Ray material, it is highly recommended to keep it like so to preserve all of its V-Ray-specific data.
Keywords are supported.
Grass and Carpet are not fully supported. Generation of grass or textile strands needs to be manually redone in V-Ray using V-Ray Fur.
Asset Support
All Enscape assets are supported by V-Ray with the exception of 3D PEOPLE assets.
Expand | |||||||||||||||||||||||||||
UI Text Box | ||
To utilize For Enscape assets to render properly in V-Ray rendering Enscape assets, you have to execute at least one Enscape render first, you have to initialize Enscape first. This needs to be done only once for the assets data to be populated in the project. Afterwards, this step must be repeated only after introducing more new assets. Once done, you don't have to start Enscape again, even if you save the project and reopen it later. |
Settings and camera exposure from Enscape are not transferred to V-Ray. V-Ray settings might have to be adjusted additionally.
Enscape procedural clouds can be replicated in V-Ray using V-Ray Procedural clouds and can also be animated for sun studies.
To stop the Enscape - V-Ray workflow, go to V-Ray menu > Preferences and disable the Enscape Compatibility option.
