width50%
The VRImg to OpenEXR converter is both a command-line utility and a simple GUI application that can be used to convert .vrimg image files to .exr files in OpenEXR format. The  The .vrimg file format is a special format used by the V-Ray VFB to store stores the rendered image incrementally while rendering, in full floating-point format, with all available render elements. The V-Ray Image to EXR Converter converts .vrimg files to EXR format so the render elements may be loaded into compositing software, where they can be used for Back-to-Beauty compositing or for other adjustments and fine-tuning at the render element level.
width5%
width45%
Image Removed Image Added
Installation
This tool comes with the V-Ray for Rhino installation. You can start the vrimg2exr executable from C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\tools .
Multiexcerpt include
MultiExcerptNamevrimgExplanation
PageWithExcerptVRAY4TOOLS:VRImg to OpenEXR Converter
MultiExcerptNameconverterGUIusage
