width50%
V-Ray Mtl2Sided material node is a utility provided with the V-Ray renderer. The material allows seeing the light on the backside of objects.
Use this material to simulate thin translucent surfaces like paper, cloth curtains, tree leaves, etc.
UI Paths: ||mat Network|| >  > V-Ray > Material > V-Ray Two Sided
width5%
width45%
