width25%
width50%
Image slider
startIndex2
Panel
borderStylenone
Diffuse Ramp with blue colors
Panel
borderStylenone
Diffuse Ramp with light green colors
Panel
borderStylenone
Diffuse Ramp with red colors
Panel
borderStylenone
Diffuse Ramp with purple colors
Panel
borderStylenone
Diffuse Ramp with yellow colors
width25%
Example: Edges Override
This examples shows the effect of the Edges Override parameter. Note that the V-Ray Toon Effect is also used for a stronger toon effect.
width25%
width50%
Before after
afterLabelon
beforeLabeloff
Panel
borderStylenone
Image Removed
Panel
borderStylenone
Image Removed
width25%
Anchor
DiffuseColor
DiffuseColor
