width50%
The core of how V-Ray determines how to render your scenes can be found within the Sampler tab of the V-Ray Renderer parameters. Some basic information on each panel can be found below, but for more details, please see the dedicated pages for each section.
UI PathPaths:
||V-Ray Shelf|| >  > ROP Parm > Renderer tab >  > Sampler tab
||out Network|| >  > V-Ray > V-Ray Renderer > Renderer tab >  > Sampler tab
V-Ray menu >  > Render Settings > Renderer tab > tab > Sampler tab
UI Text Box
typenote
When CUDA/RTX is chosen as a rendering engine, all unsupported options are disabled from the parameters.
width5%
width45%
Image Modified
Image Sampler
The Image Sampler panel controls overall image sampling. Raytrace renders, like V-Ray, shoot rays out from the camera to sample what is found in the scene to help determine what color each pixel will be in a rendered image. The settings used to adjust how V-Ray does this, and the relationship between pixels in the render, can be found on the Image Sampler (Anti-Aliasing) page.
Render Region Division
The parameters in this panel adjust V-Ray's rendering regions (sometimes referred to as buckets), when the Image Sampler Type is set to Bucket. A bucket is a rectangular (usually square) section of the currently rendered frame that is rendered independently from other sections. Buckets are used when V-Ray uses a non-progressive image sampler. For more information please see the Render Region Division page.
