This page provides information on the Caustics tab of the V-Ray Renderer.
Section | |||||
Section | |||||||||||||||||||||
UI Text Box | ||
Tips when working with progressive caustics: Required:
Optional:
Managing Expectations:
Anchor | ||||
width | 50% |
Example: The Search Distance Parameter (Progressive)
For this example,
the
light used in the scene is
V-Ray Sun. The Caustics Mode is set to Progressive. The V-Ray Sun has its Photon emission properties adjusted as so: Caustics Subdivs are set to 1500; the Caustics Multiplier is set to 2 and the Photon Radius is set to 30 cm.
Section | |||||||||||||||||||||||||||||||||||||||
Anchor | ||||
UI Expand | |||||||||||||||||||||||||||||||||||||||||||||
Column | width | 50%||||||||||||||||||||||||||||||||||||||||||||
Example: The Search Distance Parameter (Photon Map)
For this image, the light' ss Caustics Multiplier parameterparameter (||Light|| > Advanced properties rollout > Caustics Multiplier) is set to 80 and the rest of the parameters are at their default values. AsAs seen from the images, the larger Search distanceDistance produces blurrier caustics.
Anchor | ||||
UI Expand | ||
Example: The Max Photons ParameterIn this example the light's Caustics |
Multiplier parameter (||Light|| > Advanced properties rollout > Caustics Multiplier) is set to 80 and the rest of the parameters are at their default values. VRaySun is used in this scene. As can be seen, the larger value of |
the Max photons parameter causes the caustics to appear much smoother.
Anchor | ||||
UI Expand | ||
Example: VRaySun Photon Radius
This example shows how a light's photon radius affects the caustics effect. Here we use a VRaySun to light the scene. The Caustics |
Multiplier parameter in VRaySun's Advanced parameters rollout is set to 80 and the rest of the parameters are at their default values.
Progressive Caustics Advantages
