The Atmosphere Render Element stores only atmospheric or volumetric participating media such as Environment Fog or Aerial Perspective. This render element can then be used to enhance or color-correct just the atmospheric component of the image during the compositing process.
When atmospheric effects or fog is included in a scene, they will render into the Beauty (RGB color) channel, and should also be output as the atmosphere channel for compositing use.
UI Path: ||out Network||>V-Ray Render Elementsnode > >V-Ray> Render Channel> V-Ray Color Channel (RE) > Type > Atmosphere
width
5%
width
45%
width
50%
The parameters for this render element appear in the V-Ray RenderChannelColor render channels node.
Deep Output – Specifies whether to include this render element in deep images.
Color Mapping – When enabled, the Color Mapping options in the render settings are applied to the current render channel.
Consider For AA– When enabled, anti-aliasing is used where possible.
