changes.mady.by.user Gergana Lilkova
Saved on Nov 24, 2021
changes.mady.by.user Kristina Gaytandzhieva
Saved on Dec 08, 2022
The Object Select Render Element stores only the object(s) called out with a specific Object or Material ID.
This effect is reversible to create a render element that excludes a particular object or objects according to Object or Material ID.
When rendering this element out, it also includes a filter and alpha passes separately to help make it easier to use when compositing.
UI path: ||out Network|| > V-Ray Render Elements node > > V-Ray > Render Channel > > V-Ray Object Select (RE)
