Section | |||||||||||||||
Toon
Anisotropy
Bump
Shadows/Light Control
Toon Transparency
Refraction
Translucency
Options
Example: Diffuse Ramp
Edges Override
Diffuse
Bump
Reflection
Refraction
Options
Anchor | ||||
This examples shows the effect of the Diffuse Ramp. Note that the V-Ray Toon Effect is also used for a stronger toon effect.
Section | |||||||||||||||||||||||||||||||||||||||||||||
Anchor | ||||
Example: Edges Override
This examples shows the effect of the Edges Override parameter. Note This examples shows the effect of the Diffuse Ramp. Note that the V-Ray Toon Effect is also used for a stronger toon effect.
Section | ||||||||||||||||||||||||||||||||||||||||||||||
Anchor | ||||
