width50%
V-Ray Falloff produces a gradient texture based on the angular falloff of the surface of the geometry to which the texture is applied. The resulting map can simulate the falloff of opacity, reflection, and refraction for surfaces where these properties vary depending on the surface's angle to the camera, such as curved glass or water.
To create the texture, V-Ray Falloff starts with two colors, usually black and white. Placement of these colors on the surface is based on the Falloff Type and Direction Type selected. The remainder of the map is generated as a gradient between these two colors, with a gradual falloff between the colors.
UI PathsPath: ||mat Network|| > V-Ray> Ray > Texture: Procedural >  > V-Ray Falloff
width5%
width45%
width50%
Type – Specifies the type of falloff:
Towards/Away – Based on face normal directions. Faces with normals that point in the Direction Type generate Color 1 while those facing in the opposite direction (180 degrees off the falloff direction) generate Color 2
Perpendicular/Parallel – Based on face normal directions. Faces with normals that point in the Direction Type generate the Color 1 while those facing in a perpendicular direction (90 degrees off the falloff direction) generate the Color 2.
Fresnel – Based on changes to the index of refraction (IOR) over the surface due to Fresnel calculations. Faces with normals that point in the Direction Type generate the Color 1 and those facing in other directions generate varying colors depending on the IOR set by Fresnel Ior
Distance Blend – Sets the falloff range based on distance from the camera, as specified by Distance Near and Distance Far. This option is useful for generating a Z-depth type of map when rendering a very large object such as terrain, where the Falloff Map can be used as a mask to dim distant details. For more information, see the Distance Falloff Type example below.
Color 1/2 – Sets the extreme ends of the range of colors for the Falloff Map's gradient. The specific placement of these colors on the surface is determined by Type and Direction Type.
Direction Type – Specifies the falloff direction to be used by the Falloff Type.
Distance Extrapolate – Enables extrapolate for the distance blend falloff type.
Distance Near – Specifies near distance for the distance blend falloff type.
Distance FarSpecifies far distance for the distance blend falloff type.
Fresnel IOR – Specifies IOR for the Fresnel falloff type.
Use Blend Input – Enables the Blend Input parameter for controlling the blending.
Blend Input – Specifies the final blending amount that is taken from the texture.
Use Blend Curve – Enables the Blend Curve for controlling the blending.
Falloff Curve –  Specifies the falloff direction to be used by the Direction Type:
View Z/View X/View Y – Uses the camera viewing direction. This is the most common selection.
Explicit
 – Uses the direction specified by the Explicit Direction parameter.
Local XLocal Y / Local Z – Uses one of the object's local axes.
World X / World YWorld Z – Uses one of the world axes.
width5%
width45%
