The most common workflow for the Surface Luminance node attributes is to connect the node to a floating texture input slot of a V-Ray ExtraTex render render element. This way you can control the Luminance mode showing in the ExtraTex channel.
UI PathsPath||mat Network|| > V-Ray> Ray > Texture: Procedural > V-Ray Surface Luminance
