This page contains information about the V-Ray TexUserScalar node.
Section | ||||||||||||||||
Examples
In the examples below, user attributes are assigned to different objects with different values. A V-Ray User Float texture reads the values and passes them to a shader at render time. This way we can pass different shader values that are controlled at the object level, allowing us to share the shader between all objects.
