There are two environment variables that need to be set up for V-Ray for Houdini to load your custom plugin and generate the correct UI:
- VRAY_FOR_HOUDINI_PLUGINS – – this environment variable must be pointed to the folder holding the compiled plugin.
- VFH_USER_HOME – this environment variable must be pointed to a directory that contains a "ui" folder. The "ui" folder must hold a ".ds" file that shares the same name as the custom plugin. Please refer to one of the *.ds files inside the V-Ray for Houdini installation folder → /ui/plugins for examples.
UI Path: ||mat Network|| > V-Ray> Ray > Texture: Utility > > V-Ray User Plugin Shader
