UI Text Box | ||
HDRI: The HDRI assets create a Dome Light with the hdri file attached to it. It is recommended to use VRayPhysicalCamera when using Cosmos hdri files for lighting. Alternatively, you can lower the dome light intensity. |
Example
This example shows a scene without and the same scene using Chaos Cosmos assets.
Before after | ||||||||||
