width50%
V-Ray SphereFade Gizmo is a volumetric node used to render just a small part of the scene by putting it in a special spherical locator.
UI Path: ||obj Network|| > Geometry node > V-Ray > V-Ray SphereFade Gizmo
Image Modified
width5%
width45%
width50%
Shape – Specifies the gizmo shape:
Sphere
Box
Cylinder
Radius – Controls the size of the gizmo shape.
Invert – Inverts the volume that is shaded, rendering the part of the scene that is outside the sphere.
width5%
width45%
Workflow
width50%
  1. Create a Geometry node with a V-Ray SphereFade Gizmo node inside.
  2. Enable the Sphere Fade effect from |out| > V-Ray Renderer ROP > Effects > Sphere Fade.
  3. Set the color and falloff of the sphere fade gizmo.
  4. Set the shape and the radius of the sphere fade gizmo.
width5%
width45%
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/p6wVjve_1Vo" title="V-Ray for Houdini — How to work with V-Ray SphereFade Gizmo" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Example: Invert
The Invert can be turned on to only show everything visible in the scene outside of the Sphere fade volume. In the example shown below, a Falloff value of 0.2 has been used.
