UI Text Box | ||
This is an Advanced Level tutorial. The workflow for setting up the shot, and the Phoenix settings involved in the simulation are explained in detail. However, creating a production quality shot of a similar nature may require some tweaks to the it's recommended that you have at least basic knowleage in lighting, materials, and /or the Phoenix simulation. |
Section | |||||||||||||||||||||||||||||||||||||||||
Units Setup
Scene Layout
Scene Setup
UI Text Box | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
This tutorial consists of many steps to follow. To keep it concise, let's focus only on the Phoenix related steps and feel free to use the camera and light settings in the provided sample scene. For your reference, below you can find the light and camera settings.
Anatomy of Large Waves
Timeline
Determine Region for the Simulator
Set up the Ocean Texture
Adjust Ocean Texture Tiling
Set up the Phoenix Foam Texture
Simulator Region
Liquid Simulation
Set up a Wave Force
Initial Simulation
Make the Simulator Deeper
Set up Plunging Waves
Simulate Splash and Mist particles
Change Preview Color
Simulate Air Effects
Improving Pattern Formation by Mist Particles
Adjusting the Splash Particles
Increase Splash Amount
Adding Foam to the Shot
Improve Foam Settings
Position the Ship
Foam Around the Ship
Final Simulation
Set up Ocean Texture for Displacement
Water Material
Set up Particle Shaders
Final Adjustment to the Particle Shaders
V-Ray Frame Buffer
(you can download nightlies from https://nightlies.chaos.com or get the latest official )
