This page contains information about the V-Ray AovExtraTex node.
The V-Ray AOV ExtraTex (USD) node is used to export a V-Ray Extra Texture element based on the attached input. The input texture is applied over the geometry associated with the material holding the AOV bind.
UI Path: ||mat Network|| > V-Ray > Texture: Utility > V-Ray AOV ExtraTex (USD)
width50%
Extra Bind Name – Specifies the ExtraTex AOV name.
width5%
width45%
