This page provides information on the Proxy preview cache rollout in the Settings tab when the production renderer is V-Ray GPU.
width60%
The options in this rollout determine how the viewport preview information for VRayProxy objects is cached.
UI Path: ||Render Setup window|| > Settings tab > Proxy preview cache rollout (Renderer set to V-Ray GPU)
width5%
width35%
width60%
Enable preview cache – When enabled, viewport preview information for all VRayProxy objects in the scene is cached for every frame, thus speeding up viewport drawing and responsiveness.
Reset cache – Clears all cached information.
width5%
width35%
