Preview & Render Cache Path | rendinput – Gives the directory and the name template for the input files – This is the path to the cache sequence to shown in the preview and rendered. The default is $(same_as_output). Use the button to select the path or type it manually. Phoenix has some keywords that can be used for more flexibility:
