VRayToon is a very simple atmospheric plugin that produces cartoon-style outlines on objects in the scene. The settings for a single VRayToon atmospheric are applied to all objects selected for inclusion. Multiple toon styles can be represented in a scene by creating several VolumeVRayToon atmospherics and including/excluding different sets of objects.
VRayToon has been implemented as an atmospheric effect for several reasons:
Fancy Bullets
type
circle
Very simple implementation.
Works with any geometry supported by V-Ray, including displaced objects, Procedural Fur and Proxy Objects.
Works with any camera type supported by V-Ray (spherical, fish-eye, etc.).
Works with any camera effect (depth of field and/or motion blur).
Works with ray traced effects such as reflection and refraction.
Smooth and consistent outlines for intersecting objects.
VRayToon is not intended to be a full NPR (non-photorealistic rendering) effect. However, it may be useful in many cases.
The source of VRayToon is available as part of the V-Ray SDK.
UI Text Box
type
tip
VRayToon effect must be added in a V-Ray Environment node (out network) to work.
